rear tires 4 400 exer
Old Aug 6, 2000 | 01:52 AM
redridaz513's Avatar
i need to know with tire slides the best,corning my exer is a real challenge, with stock tires,it seems to hook up to much . please help
Old Aug 7, 2000 | 03:15 PM
snowshark's Avatar
Try adding more air in the rear tires. Try 6-8 pounds of air pressure. The extra air pressure should make them slide pretty good.
I have ridden my friends 400EX & it will power slide when you want it to.
Old Aug 7, 2000 | 04:07 PM
Mike Frey's Avatar
8psi is way too much. It slides very well, but everytime you give it throttle, the back end breaks loose. Try 4 or 5psi. I run 4.
Old Aug 7, 2000 | 05:07 PM
Santa's Avatar
Try RAZR's. The sidewall is very stiff, which makes sliding easy!
Old Aug 7, 2000 | 08:05 PM
snowshark's Avatar
I know 8 pounds is a lot for tire pressure, but if he can't get the rear end to break loose with only 3-4 pounds the you surely will be able to with 8.
You could do donuts all day long.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Polaris5
Aug 29, 2015 09:11 PM
rcappie4
Jul 18, 2015 07:51 AM
rcappie4
Jul 10, 2015 04:54 PM
