Pink Spring on a P650?
Old Jun 15, 2004 | 12:40 AM
BD's Avatar
BD
Default Pink Spring on a P650?
Are the Prairie and Vforce primary springs compatible? If so, what performance differences should I expect upon installation? Appreciate the help.
Old Jun 15, 2004 | 09:05 AM
newbeatle's Avatar
yes they are compatable... Both KISSOFDEATH, & MIKEYBOYESQ, have done spring tests... I my memory is correct, the O.E. 700 spring, Dalton plain white, & EPI pink, were best trail springs... there are literally 10 -20 different springs to choose from... I believe Nyroc has a sapring chart on his website...
Old Jun 16, 2004 | 12:11 AM
KawiTuner's Avatar
get the blue spring from dalton ind. It works great.
I would also recommend the secondary spring also.
Old Jun 16, 2004 | 11:50 PM
kawiyowee's Avatar
Called EPI for their recommendation on the primary....they asked what size tires I had, 25", then said use pink spring. Kawituner may be right about the dalton blue because of your 26".
Don't know what EPI would suggest for your tire size. I know if you can keep from jolting your drivetrain too hard at takeoff, (pink spring is almost stock at low rpms) it's easier on the components.
Old Jun 17, 2004 | 12:42 PM
BD's Avatar
BD
Thanks for the help!
Old Jun 20, 2004 | 11:43 PM
KawiTuner's Avatar
BD PM me in a week or 2 I will give you a update on another primary spring we are testing. I think it may be what the doctor ordered.
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
chuck1177
Aug 11, 2015 03:22 PM
Mphillips
Jul 2, 2015 07:20 PM
