why do i have to put different amounts of air in my tires to get it to drive straight?
i bought some tires and they didnt work right they pulled bad to one side with the same amount of air so whats the deal
yea its the rear i got the tabs lined up the axle dont wobble or anything so what how do you tell to get the swing arm bolds the same
Use a soft tape measure and go around the out side of the tire when the both have the same amount of air in them. Sometimes one tire will be larger than the other causing your problem.
You can check for alignment by using the same tape and measurring from your axle to somewhere solid on your frame, like the footpegs.
did u buy them new or used? because if they were running one way and u put just one the other way it will pull!!!!!!!!!!!!
Jul 24, 2015 11:57 AM
