Sportsman tire sizing..Help....
Old Aug 6, 2000 | 06:54 PM
PADZZ's Avatar
Have a '99 335 and was wanting to go 25" all the way around. It currently has stock 23 front and 24 rear. I heard it may mess up the 4WD...but I think the 2000 models have 24's all the way around. If 25's won't work, I'll go 24 front and 25 rear. Probably bear claw or that new GBC tire. Also, will this hurt the speed/performance??I'll surely stay away from Titan. Any suggestions/help is appreciated.
Thanks, Drew
Old Aug 6, 2000 | 07:18 PM
Hugh's Avatar
What's wrong with the titan...........I saw a test report in on of the atv mag that rated the titan 589 better than anything on the market. That was going to be my next choice for my SP500. Let me know the bad news.
Thanks
Hugh
Old Aug 6, 2000 | 11:06 PM
SWAC1's Avatar
Subtle differences between stock and newer tire diameters won't make a mess of your quad unless you plan on doing a lot of 4 wheeling (AWD) on pavement or really solid turf. Soft ground, sand or mud should not mess up anything in the architecture of your drivetrain while engaged in the AWD zone.
Old Aug 7, 2000 | 12:18 AM
quad_man's Avatar
You should be fine 25" all the way around. I have seen quite a few 335 running stock tires off a Sportsman 500. It hurts power some though.
Old Aug 7, 2000 | 12:23 AM
Deej's Avatar
Padzz,
The gearing in the tranny that spins the front and rear shafts is setup to accomodate different size tires in the front and rear. The front hubs spin faster than the rear hubs because the front tire was intended to be smaller. If you make all 4 tires the same size then the fronts are trying to spin faster. On soft ground this MAY never case a problem. On hard ground it will strain the drive train (only when AWD is selected and engaged).
The AWD front hubs are mechanical in nature and engage only when the rear wheels spin faster that the fronts (and the AWD switch is on to provide power to the AWD coils). Playing with the tire front/rear size ratio will have an effect on when the AWD mechanical hubs engage.
To an extent I agree with SWAC1. Mild tire size changes will not affect things, as long as the ratio of front to rear remains roughy the same. ie, do not make them all the same size. If you go up a size in the rear, go up a size in the front (not two sizes).
Remember, the bigger the tire, the harder the engine works to turn it. There will be a difference in power output.
DJ
Old Aug 7, 2000 | 08:59 AM
PADZZ's Avatar
DJ...thanks for the reply! That Helped...
Hugh...I was referring to the 489's that came stock. It's only the front tires I've had problems with. Both front tires are new and both have plugs...the rears have held up though.
Old Aug 7, 2000 | 10:32 AM
gregsims's Avatar
I have studdied the polaris shop manual for some time, and my understanding is that if the front tires are not taller than the rears, you will be OK. I have a friend that has a Sp335 with 25" mud tires and it has not been a problem.
Greg
Old Aug 7, 2000 | 01:24 PM
Rammer's Avatar
The SP335 uses the SAME gearing as the SP500 that has 25" tire all the way around. Even the '00 SP335 use 24" all around. Smaller tires up front make the AWD engage a tad latter. It needs more rear wheel slippage to engage. It's hardly noticable.
Jmuddin284
Jan 19, 2026 07:16 AM
Big bousse
Sep 26, 2015 10:42 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
