oil weights for 700 efi
does anyone know the oil weights for the sp 700 efi. the tranny, is sae 80w-90, i believe. but what about the front gear case and the rear grear case. is anyone using anything other then the polaris oils. i want to go full amsoil sythintics on my machine. i couldn't find it in my service manual ed and just wondering what you'all think and or doing. dan-o
I just changed all the oils in my HO and from all the posts I read on other fourms I opted for the Polaris premium synthetic gearcase lubricant for the transmission. With the front gear case thats were their different, mine takes 80w90 syntic/gear were your's would take Synthetic ATF. You could use 80w90 synthetic gear in the rear gear case. From what I have read the oil in the transmission is more of a synthetic chain case oil and the 80w90 synthetic gear oil is not a good replacement, even though I have used it in all of my Skidoo chain cases with no problems....... my first Polaris.
I'm not sure which amsoil oils to use, i know lots of people use them, here's the polaris oils to use
Front gearcase (awd hilliard)- Premium Demand Drive Hub Fluid (similar to a ATF fluid), this is a sensitive component, be sure to use the right stuff
Transmission - Polaris AGL Lube
Rear Gearcase - 80-90w oil will work fine
Engine - Polaris 0W-40, i think asmoil makes the same weight oil
Radiator takes a 60/40 blend from the factory
Steeldon
Sep 9, 2015 09:38 AM
