oil weights for 700 efi
Old Jun 17, 2004 | 10:16 PM
Diesel3247's Avatar
Default oil weights for 700 efi
does anyone know the oil weights for the sp 700 efi. the tranny, is sae 80w-90, i believe. but what about the front gear case and the rear grear case. is anyone using anything other then the polaris oils. i want to go full amsoil sythintics on my machine. i couldn't find it in my service manual ed and just wondering what you'all think and or doing. dan-o
Old Jun 19, 2004 | 04:45 PM
Diesel3247's Avatar
does any one know or haven't tried anything other then the polaris oils......
Old Jun 20, 2004 | 12:13 AM
NBsportsman's Avatar
I just changed all the oils in my HO and from all the posts I read on other fourms I opted for the Polaris premium synthetic gearcase lubricant for the transmission. With the front gear case thats were their different, mine takes 80w90 syntic/gear were your's would take Synthetic ATF. You could use 80w90 synthetic gear in the rear gear case. From what I have read the oil in the transmission is more of a synthetic chain case oil and the 80w90 synthetic gear oil is not a good replacement, even though I have used it in all of my Skidoo chain cases with no problems....... my first Polaris.
Old Jun 20, 2004 | 01:42 PM
predatordude's Avatar
I'm not sure which amsoil oils to use, i know lots of people use them, here's the polaris oils to use
Front gearcase (awd hilliard)- Premium Demand Drive Hub Fluid (similar to a ATF fluid), this is a sensitive component, be sure to use the right stuff
Transmission - Polaris AGL Lube
Rear Gearcase - 80-90w oil will work fine
Engine - Polaris 0W-40, i think asmoil makes the same weight oil
Radiator takes a 60/40 blend from the factory
Old Jun 20, 2004 | 05:37 PM
I also used the Amsoil 0w40 four stroke oil in the motor. The synthetic ATF I used in the front hubs was Mobil 1....
Old Jun 20, 2004 | 09:17 PM
BigBadScrambler's Avatar
If the EFI uses the same Polaris chaincase lube that the other models (Scrambler, Trailblazers, Sportsman 500's) use then Amsoil Series 200 Chaincase lube will work
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
