counter balancer??
Old Jun 18, 2004 | 02:08 AM
scrambler123's Avatar
Default counter balancer??
ok the dipstick for checking the counter balancer is the big black plug with the flat head screwdriver slot correct? should the dipstick read just on the rough portion at the very bottom? mine reads dry right now. any help would be appreciated
Old Jun 18, 2004 | 07:46 AM
ftwflh's Avatar
Should be on the rough part.If there isnt any on the pull the plug to get the rest out and refill it.Dont worry if you over fill it excess will go out the vent.If it is bone dry expect to bereplacing the seal soon if not the complete unit.
Old Jun 18, 2004 | 09:49 AM
quadwrench's Avatar
Just to add to ftwflh, the balance sump only holds about 70cc's of oil (not a whole lot). If you experience excessive smoking from the exhaust pipe when running, then the crankshaft seal inside the oil sump is probably leaking, allowing the "suction" of the engine to pull the oil through the seal - this may be just a bad seal, or the crankshaft bearings may be worn (allowing the crank to "flop" somewhat, opening up the seal lip) - if you decide to go in and repair it, I would suggest replacing the waterpump bearing and seals while you are in there.
Old Jun 18, 2004 | 10:36 AM
Bradracer18's Avatar
To add to what these guys have said......just change the oil, its not that expensive and then you know what you got......you drain it from the underneath side, under the skid plate. The dipstick thing, I never really used that.....I always change it before it would need checking. Also when filling it, there is a plug, on the underneath side of the exhaust port, I think, but on the front of the motor anyways.....and when you fill, leave the plug out of there, and when it runs out of the hole....its full. That is how it is supposed to be done.
Old Jun 18, 2004 | 05:46 PM
thanks a lot.
Johnny Mac
Aug 15, 2019 03:13 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
TeamGreen
Oct 25, 2000 10:50 AM
250rampage
Jul 14, 2000 12:11 AM
