New Shocks for Warrior
I rode a stock 2000 banshee this weekend and could not believe the suspension!
Then I got back on my 95 Warrior... it felt like I had no suspension.
Can My Warrior ride like that?
How much will it cost me?
Where should I buy from?
Thanks.
Thanks.
Well it depends on how much you really want to spend. You can get works Steelers for the front for about 250-300 dollars. The back shock on the Warrior ain't that bad so I'd just recommend front shocks. If you want some of the best front shocks, TCS has them for $750. Check this site out http://ctracing.com/suspensi.htm
Want a tip on how to make the frt suspension better on the Warrior? You can fit up any set of Banshee front shocks onto the warrior without problems! The length is about a half inch longer, which will increase the travel. I had a pair of Works Performance shocks off of my Banshee that I was not using, and they bolted on without problems. The action is so much better than the stock shocks, with about 1.5 inches more travel to boot. I also had Works Performance custom make a rear shock 1/2 inch longer, which also increased the travel. This combination gave my Warrior a suspension every bit a plush as a Banshee. Longer shocks are the answer, because they fit perfect! Looks cool too. Not too many people know about this.
