1984 250r engine swap!?!?!
Old Jun 20, 2004 | 08:43 PM
MJH311's Avatar
Default 1984 250r engine swap!?!?!
Hey... i bought a 1985 ATC200x and when i got it i knew that the engine was messed up... but it turns out that the bottom end is bad.... my buddie has a 1984 250r and i was wondering if any one knew if i could do an engine swap... if so... are the wires the same???? thanks everyone
Old Jun 20, 2004 | 09:30 PM
HMFIC's Avatar
Why can't you just fix up the 84 250r. If you do the motor swap you will need the coil and stuff off of the R anyway. As far as the 200x goes if you really want to make it rip you need to go into the bottom end anyway. Check out powroll.com for some hop-ups for the 200x.
Old Jun 20, 2004 | 09:40 PM
MJH311's Avatar
i cant do ne thing to the bottom end of the 200x cuz the crank if messed up and they told me that it would not be worth grinding down.... and could i just bolt the 250r motor stright up to the 200x frame cuz all he has is the motor nothing ealse no frame for the motor.
Old Jun 20, 2004 | 09:48 PM
HMFIC's Avatar
Well there shouldn't be that much to it then. As I said before you will probably need the coil off of a 250R. That thing ought to be pretty fast with that engine.
Old Jun 20, 2004 | 10:42 PM
BeerSmurf's Avatar
It will be more work to put the '84 motor in the X than to just fix the '84.
The '84 is better than a bastard 200x ever will be.
For that matter pick up a used 200X motor on ebay for a few hundred and be happy.
I have an '84 250R and an '84 200X and am NOT 12 years old.
Old Jun 21, 2004 | 12:38 AM
KNOWSALOT's Avatar
The Facility
The R engine will not work in the X frame without serious fram modifying. The X front lower down tubes do not "spread" for the R exhaust to fit through.
Old Jun 21, 2004 | 02:13 AM
ThrashAndCrash's Avatar
Where you been "Knowsalot"?...been awhile since we have seen you in the ATC forum....
Old Jun 21, 2004 | 11:20 AM
Lomax's Avatar
The Chain is also on the right side instead of the left like almost everything else.
bzdok1234
30
Feb 23, 2016 01:55 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
timster911
Jul 13, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
