What oil weight, oil capacity, and which filter to use on a 2004.5 Sportsman 500?
Old Jun 25, 2004 | 03:37 PM
AJC629's Avatar
Default What oil weight, oil capacity, and which filter to use on a 2004.5 Sportsman 500?
Brother just bought one and can't find specs anywhere and needs to change the oil!
Oil weight and recommended brand?
Oil filter brand and part #?
Oil capacity with filter change?
Old Jun 25, 2004 | 03:44 PM
BigBadScrambler's Avatar
2 quarts of oil (after you drain the crankcase too and filter) of 0W-40 Synthetic motor oil. Either the Polaris brand, Amsoil 0W-40 4 stroke, or Mobil 1 0W-40 "European Car Formula". And you can use a Napa Gold filter #1358
Old Jun 25, 2004 | 04:51 PM
Charlie's Avatar
Its in the owners manual, it says API rating SH and has to be a viscosity of 0W-40.
Old Jun 25, 2004 | 07:20 PM
rsking45's Avatar
go to your nearest polaris dealer and get a oil change kit. It has everything you need plus instructions on how to do it.Id also have them order you a shop manule if you plan on working on it your self.Be carfull if you take the oil line off to clean the screen i have heard of the plastic oil tank cracking when removing the line.Make sure to prime the oil pump after if you disconnnnect the line.
lightninboy
May 16, 2021 09:52 PM
RedRancher
Oct 15, 2020 01:45 PM
GregM
Jul 29, 2015 09:41 PM
baysport
Jul 23, 2015 11:37 AM
bpegram84
Jul 22, 2015 08:15 AM
