Would I need to rejet if I install stock V-force cams on my P650?
Old Jun 25, 2004 | 06:32 PM
MikeyBoyesq's Avatar
Default Would I need to rejet if I install stock V-force cams on my P650?
As I understand it, stock V-force cams have the same lift and duration as stock P650/P700 cams do...but the only difference is that the V-force cams are retarded 10 degrees as compared to the Prairie cams. Based on the fact that the lift/duration is the same, it seems to me like I should NOT have to rejet my carbs if I install V-force cams. Is this correct?
For anyone who has already installed V-force cams into a P650/P700, please let me know if you had to rejet. My guess is no.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 25, 2004 | 10:54 PM
KawiTuner's Avatar
just check out the jetting specs on the V
Old Jun 26, 2004 | 04:38 PM
NovaKaw650's Avatar
My stock cams are rolled back to V-Force specs, I jetted slightly larger, but had other stuff going on at the same time. Your running Dial-a-Jets; all you'd have to do is open them a little.
My current jetting is at 148F-150B Keihin jets.
Old Jun 28, 2004 | 12:12 PM
NovaKaw,
Thanx for the input.
fordfaithful21
Dec 7, 2015 05:52 PM
black_thunder
Sep 7, 2015 01:24 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
toonces
Sep 5, 2015 01:14 PM
