Cleaning my WHITE plastic.... Whats best?
Old Aug 8, 2000 | 10:01 PM
blazer1969's Avatar
I own a 2000 TRAIL BLAZER and plan on putting it in the Cycle Trader this week. I need to clean it up a little before I sell it. Anybody know good safe way to clean up the plastic? I live in West Georgia-where the dirt is good ole GA red clay. The White has a slight orange tint to it and I would like to try and make it look better before selling it...........
Old Aug 8, 2000 | 10:36 PM
clindst's Avatar
try WD-40 or "Son of a Gun" its a degreaser or try simple gasoline
Chris
Old Aug 8, 2000 | 10:42 PM
blazer1969's Avatar
Gasoline? That will take all of the shine off of the plastic!
Old Aug 8, 2000 | 10:45 PM
clindst's Avatar
well use gas if WD40 or SON of a GUn doesnt work then try gas that should work the when done with gas use Son of a Gun to shine it back up
Old Aug 8, 2000 | 11:06 PM
MagnumMudMan's Avatar
blazer
To clean the plastic, use water with a good detergent such as simple green. This should get the Georgia clay off. Then use Armoral or Son of a Gun to shine the plastic up. This is the simplest and safest way to get it clean.
Clindst : Gasoline is not safe to clean anything. I know you are young, so heed all warnings. Gasoline should be repected and not used as a general cleaning agent. Put it into the tank and the tank only.
Old Aug 8, 2000 | 11:10 PM
mudmachine's Avatar
Blazer,
Believe it or not... its a lot easier than it seems...
My son has a Honda XR-80R dirtbike with the while plastic. The EASIEST thing to use is some Soft Scrub with Bleach. Wet the plastic down, put a little on a plastic scrub brush, and apply and rinse off...
The plastic is WHITE and shines like new!!...
Old Aug 9, 2000 | 12:20 AM
will's Avatar
Why are you selling it?? I was just wondering because mine is really starting to **** me off. I have worked on it more than any other atv I have owned in the past 3 months that i have had it.
Old Aug 9, 2000 | 12:44 AM
ChevyTruckn's Avatar
Have you tried the 2001 car polish (comes in a bright green bottle)? I know it works good for getting the dirt out of the scratches. I don't see why it wouldn't work. Just put it on like you would on a car.
Old Aug 9, 2000 | 12:51 AM
THEXOTIC1's Avatar
straight bleach or wd 40 and a scotch brite pad. after cleaning the plastics. put a couple of coats of mop and glo floor shine . it makes the plastics look new...
Old Aug 9, 2000 | 02:10 AM
CHICKENman's Avatar
MOP& glow is hard to beat you may have to put several coats on just wait between coats for it to dry.First couple look terrible then it begins to shape up.CM
