How does a fuel filter effect performance?
Old Aug 9, 2000 | 11:49 AM
DeadEye's Avatar
How does a fuel filter effect performance? Good or Bad?
Old Aug 9, 2000 | 11:56 AM
tempest's Avatar
Are you talking about an additional in-line filter?
Temp
Old Aug 9, 2000 | 11:59 AM
snowshark's Avatar
A fuel filter should NOT effect the performance of the ATV. If it does there is something wrong.
Old Aug 9, 2000 | 12:24 PM
DeadEye's Avatar
yeah, an in-line fuel filter.
Do they just screen out large peices of trash that are in the gasoline?
Old Aug 9, 2000 | 02:55 PM
hot_shoe_cv's Avatar
The chief effect it would have would be to allow the machine to continue performing by trapping the impurities in your tank or fuel.
Old Aug 9, 2000 | 04:24 PM
TheGerk's Avatar
It will add about 30-40 horsepower!! i put two on mine, now it kicks !!!
Old Aug 9, 2000 | 05:24 PM
maxtrax's Avatar
The performance of your machine would only be affected negatively with an additional filter if you had a pressurized system, which you do not.
Max
Old Aug 9, 2000 | 07:28 PM
DunePilot858's Avatar
Why would an additional filter effect a pressurized system? The system would still force the fuel into the filter until it was filled up. The only way a fuel filter could possibly be bad would be if it was plugged up or not allowing enough fuel through it starving the engine of fuel (leaning the motor out). Hopefully this wouldn't happen since I'm sure you would not want to see daylight through your piston.
Old Aug 10, 2000 | 03:04 AM
azrob's Avatar
Fuel filters are usually installed to prevent future crap entering your carb, possibly clogging a jet or something.
Old Aug 10, 2000 | 07:43 AM
maxtrax's Avatar
A pressurized system requires a filter designed for this system. not all filters can be used. therefore a fuel starvation problem would be present.
max
