Why is stock header pipe wider in circumference than my GYT-R?
i noticed that at the part coming out from the engine the stock header pipe is a wider than the gyt-r one. why is this? shouldnt the gyt-r be wider?
not nessesarily... but if u can try it put stock header on and run it like u normally do then stock and run it same way... see i f u see a dif and chagne accordingly [img]i/expressions/face-icon-small-smile.gif[/img] JMO
Thats odd, my sparks pipe is wider from the head to the tail end. I guess it is just who makes the pipe and does their homework.... JMO
The gytr head pipe is smaller than the stocker because its designed to work with stock engines. A smaller headpipe is better for stock engines but the larger pipe allows for headroom for future modifications. You lose some midrange with a larger diameter headpipe.
-bLuRRRR27-
LOL, in all your posts, I see you badmouth Yoshi, and then compliment the GYT-R. Just what i've noticed.
mrtidy
Feb 3, 2016 05:00 PM
