Scambler hates to get wet
Old Jun 29, 2004 | 11:32 PM
MOJeepr's Avatar
Default Scambler hates to get wet
I recently purchased a barely used 04 Scrambler 500. Well, four times now when I've splashed through shallow water or today even when I washed it, it won't run right afterwards. It will idle, but if you try to give it gas, it just cuts out and looses power. If it sits for a while and dries out, it will go back to running okay. I realize it's likely something electrical getting wet, but where do I start? There are a lot of wires in there! Any advice will be appreciated!
Old Jun 29, 2004 | 11:48 PM
ftwflh's Avatar
Start by checking the plug wire and boot.
Old Jun 29, 2004 | 11:49 PM
tbsleeper's Avatar
your gettign water into the belt somehow it sounds like. check the cvt cover for crack or holes.
actually!! take it off i bet its missing the seal!! i forgot to put mine on once and thats exactly what it did!!
Old Jun 29, 2004 | 11:50 PM
tbsleeper's Avatar
does it idle but when u hti the gas it bogs and will basically shut off unles u let off the gas. right?
Old Jun 30, 2004 | 12:03 AM
MOJeepr's Avatar
ftwflh--Okay, so a dumb question, I see the spark plug hiding up there, but how do I get access to it? I was going to check that.... should be okay since quad is fairly new, but maybe it is loose or something.
tbsleeper--I don't think it's the belt, as it's not slipping, the engine cuts out. It is exactly as you describe in your second post, where it just cuts out & bogs unless I let off the gas again.
Old Jun 30, 2004 | 12:27 AM
BigBadScrambler's Avatar
The easiest way to get the plug out is honestly to take the front plastic and gas tank off. Kinda sucks, but they really buried that sucker in there
Old Jun 30, 2004 | 02:22 AM
montecarlo97's Avatar
My wifes 2004 trailblazer does the same thing. I'll blast through a shallow creek on my Scrambler and when she goes through it, her trailblazer bogs down. She can give it full throttle and it will barely move. She has to put it in neutral and rev it up a few times and it's fine. I've gotten the belt wet on my Scrambler a couple times and it's not the same thing.
Old Jun 30, 2004 | 03:04 AM
jimmypsp700's Avatar
That's what Polaris recommends to dry out the CVT , put it into neutral and rev it. I'd check the seal. I don't have any problems in the water and I get in 4 inches or more over the floorboards.
Old Jun 30, 2004 | 03:13 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
he is talking about the engine,,,not the tranny
04scrammy trace the whole electrical system,,,and be sure it is right,,,use some 'wire drier' as well.
Old Jun 30, 2004 | 09:53 AM
ftwflh's Avatar
You should be able to take the right side tank panel off and work your hand up to the plug.
