Trading in 00 Mod Banshee
I was going to trad in my 00 Mod Banshee for a 05 LE YFZ 450. But they only want to give me $2500 for it.
Here is what is done to it
FMF Fatty Pipes & Power Core 2s
Cool Head with 21cc domes
Race Logic Porting
Vitos Power Pistons
28mm Flat side Carbs
V-Force Delta 2
Vitos Degree key
Boost Bottle
Team Alba Clutch Kit
Hinson Clutch Basket
Hinson Cushions
Hinson Pressure Plate
Pro Flow kit
6 Filtered Air Vents
Laegers Pro-Trax +2 A-Arms
Laegers Pro-Trax Swing Arm
PEP Steering Stabilizer
Work Ultracross Rear Shock
Custom Axis Dual rate front Shocks
Internal Thermal Water Pump Cover
High Volume water Pump
Aluminum Dipstick
20 Fin super Cooler
Hinson Clutch Cover
Rad Racing Axle Carrier
X33 Dura Blue Axle
Renthal Handlebars
Pro Design Kill Switch
Nacs Black Number Plate with white Number 1
Nacs Decal Kit
Aluminum Silencer Hangers
Dure Blue Posi-Lock Axle Nut
PEP Clutch Lever
Pro Design Power Shifter
FootPag Extenders
GaryDon Nerf Bars
15/41 Gearing
ITP Race Rims
Razr 2 Rear Tires
Razr Front Tires
Twist Throttle
DG Front Bumper
AC Swingarm Skid Plate
Diamond Plate Chassis skid Plate
Nacs Mag Cover
Nacs Water Pump Cover
Nacs Kick Starter
Nacs Parking Brake Block Off
Nacs Front & Rear Master Cylinder Cover
Maier Race Cut front Fenders (Red)
Maier Rear Fenders (Red)
Maier Gas Tank Cover (Black)
Maier Radiator Cover (Black)
Nacs Yellow Handlebar Pad
Moose Black Shock Cover
EBC Brake Rotor
Yellow Hurricane Grips
Yamaha LE Banshee seat
Red Grease Zerk Dust Caps
Yellow/Black/Red Headlight Covers (Eyes)
Aluminun Exhaust Clamps
Toomey Radiator
Aluminum Gas Cap
Aluminum Handlebar Clamp
X Ring Gold Chin
High Output Stator
Cascade Chain Slider (Yellow)
I thank that is it
Race Logic Porting
Vitos Power Pistons
V-Force Delta 2
Vitos Degree key
Boost Bottle
Hinson Cushions
Pro Flow kit
Aluminum Dipstick
20 Fin super Cooler
Hinson Clutch Cover
X33 Dura Blue Axle
Renthal Handlebars
Nacs Decal Kit
PEP Clutch Lever
FootPag Extenders
GaryDon Nerf Bars
15/41 Gearing
ITP Race Rims
Razr 2 Rear Tires
Razr Front Tires
Twist Throttle
DG Front Bumper
Nacs Mag Cover
Nacs Kick Starter
EBC Brake Rotor
Toomey Radiator
Aluminum Gas Cap
X Ring Gold Chin
High Output Stator
I thank that is it
i think your goin to miss the sounds, smell, and powerband hit of it. if you traded it into your dealer they would give ya 2500 for it but then turn around and sell it for like 7g. i've seen it done before.
I am not going to trad it in I might try to sell it out right. I dont want to sell it but we have been having this problem with it when it is Cold or warm it will run like $hit and when it is hot it runs real good the plugs are a Nice Brown Color and it is getting gas. We just cant find out what is the Problem with it.
It is the Left side we are have Problems with
