Buddies Warrior running like crap....
Old Jul 1, 2004 | 10:09 AM
JoshCVBz's Avatar
Default Buddies Warrior running like crap....
Hey Guys,
Last night a friend of mine came down and we were ridin around a little bit. His Warrior seemed to be running fine....ran for probably 1/2 hour or so, then we shut them off for a second. When he started it back up, it ran like crap....It would idle fine, but if you gave it any gas it would cut out, and spit and sputter....almost like what a quad would do if you tried riding with the choke on. We didn't have a lot of time to mess with it, so all we did last night was pull the air intake off to check and see if the carb slides were opening, and they were. I'm not incredibly smart, so I was wondering if you guys had any suggestions on what to look for tonight?
Could it be the main jet is clogged? It's just weird that it was running perfectly fine the instant we shut it off, and then 5 minutes later it was running like crap. We already checked the air filter, and it's nice and clean.
There is a wire that runs from underneath the motor, right through where the shift lever attaches, and then back up...it was really hot, but I didn't see that it was exposed or anything.....just seems like a weird place to route a wire....Just mentioning it incase it's not normal....probably is though.
Thanks for any ideas you can provide.
-Josh
Old Jul 1, 2004 | 10:29 AM
quadracer18's Avatar
So all its doing is idling fine???? in that case you wouldn't have mid range or top end.....well the first thing that comes to mind is the jets....your needle controls your midrange and the main jet is the top range...you might want to yank the carb...clean it out and then hit everthing with some gunkout....but the way you explained it I really don't see anything that you did that would effect the needle and main jet...you might also check the compression...On my scrambler..I went riding and then all of a sudden I lost all my power and the thing kept bogging down...the reason~ I got a crack in my header pipe and I lost all of my compression...so check and make sure your still getting compression.........did he use the choke to start it up (the time when you found out it wasn't running right) if so..check the cable and make sure it retracted back in................as for the wire...beats me...I've never had a warrior so I'm not to familiar with one...
Good luck getten her running again
Old Jul 1, 2004 | 11:09 AM
JoshCVBz's Avatar
Thanks man....we are gonna start with the carb, and see what's up.....Very weird that it all of a sudden started doing it....He did not use the choke to start it except for the very first time of the evening.
I'll see if I can snag a compression tester from our local garage and check that too....also will inspect the header and make sure they are bolted down good and in good shape....good idea.
-Josh
Old Jul 1, 2004 | 11:12 AM
warrior68man's Avatar
Dude! Stop! It is your parking Brake! Don't go ripping into the quad! Check to see if the parking brake is even a little engaged...It was on mine and it almost made me tear the carb apart. Check that before anything.
And it made it run the same exact way.
Old Jul 1, 2004 | 11:30 AM
JoshCVBz's Avatar
You know what....My Banshee used to do that....I should have thought of that. Good call man, you could be right. Will keep you posted.
-Josh
Old Jul 1, 2004 | 11:39 AM
pinheadedjoker's Avatar
Yeah i got 100 on the parking brake also.. happened to my raptor.. drove me crazy for about 2 months.. lol it wasnt exactly the parking break because i thought of that.. it was one of those other things that goes wrong with the raptor " the rev limiter" stupid raptors always having issues.. they need to invent a bike that doesnt use gas that has tons and tons of hp doesnt use oil doesnt require maintinence and is just perfect.
Old Jul 2, 2004 | 10:06 AM
JoshCVBz's Avatar
Thanks guys....it was the parking break....Glad you mentioned it or it probably wouldn't have dawned on me until 3am 3-weeks from now...hahahah.
Warrior68man....email your address to me, I have something to send you in appreciation of your help. josh@cvboyz.com
Thanks again.
-Josh
Old Jul 2, 2004 | 10:15 AM
K It's emailed to you.
Old Jul 2, 2004 | 06:57 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i was gonna say it was parking break but o well u got to it b4 me [img]i/expressions/face-icon-small-sad.gif[/img]
njrider64
Jul 4, 2017 01:40 AM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Nelson
Jun 20, 2015 01:59 PM
fullprice54
Jun 18, 2015 09:44 AM
mikey426
Jun 17, 2015 03:53 PM
