Polaris Xpedition 425 2000 HELP!!
Danman i'm not sure but I would think it would be the same as I use in my 2002 Sportman and Scrambler. I use Polaris hub oil. You should have a drain set screw in each hub. Take out drain screw and turn drain hole to 6[img]i/expressions/face-icon-small-blush.gif[/img]o position to drain most of the old oil out. Turn to 12:00 position and add some oil, turn to 4:00 position and see if any drains out. If not then you need to add more oil and repeat until oil starts to come out at the 4:00 position. When it stops you should have the right amount of oil in each hub.
When you have all finished bragging, this is a work vehicle not a toy.
Beltdrive do you know the Grade of the oil that would be great thx.
As a substitute, you can use ATF type F, or even better, use Mobil 1 synthetic ATF. I have found the Mobil 1 to work the best, plus you have lots lefts over for nest time. Beltdrive covered the refilling procedure though.
