Polaris Xpedition 425 2000 HELP!!
Old Jul 1, 2004 | 03:43 PM
danman10's Avatar
Default Polaris Xpedition 425 2000 HELP!!
Hello, can anyone tell me what oil and the amount to use in the front hubs, of the Polaris Xpedition 425 2000 model.
Thx Dan
Old Jul 1, 2004 | 06:40 PM
BeltDrive's Avatar
Danman i'm not sure but I would think it would be the same as I use in my 2002 Sportman and Scrambler. I use Polaris hub oil. You should have a drain set screw in each hub. Take out drain screw and turn drain hole to 6[img]i/expressions/face-icon-small-blush.gif[/img]o position to drain most of the old oil out. Turn to 12:00 position and add some oil, turn to 4:00 position and see if any drains out. If not then you need to add more oil and repeat until oil starts to come out at the 4:00 position. When it stops you should have the right amount of oil in each hub.
Old Jul 1, 2004 | 07:53 PM
Hairback357's Avatar
Yep it is the same.
Old Jul 1, 2004 | 08:20 PM
ATVman00169's Avatar
danman10.
you should sell me your xpedition. [img]i/expressions/face-icon-small-happy.gif[/img]...nice bikes.
Old Jul 1, 2004 | 08:47 PM
QuadLT500Racer's Avatar
my dealer still has a left over 2000 on the floor lol. they suck they fall flatter and flatter on there face as u upshift [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 2, 2004 | 12:39 AM
Not with a couple of mods they don't. I weigh 300lbs and my Xpedition flys now and I still have one more motor mod to do yet. Great quad, wish I had 2 of them myself.
Old Jul 2, 2004 | 07:29 AM
danman10's Avatar
When you have all finished bragging, this is a work vehicle not a toy.
Beltdrive do you know the Grade of the oil that would be great thx.
Old Jul 2, 2004 | 11:08 AM
Beltdrive answered your question. Told you what oil to get and even how to put it in. What more are you looking for?
Old Jul 2, 2004 | 06:19 PM
BeltDrive's Avatar
I don't know for sure, but it is like a auto trans fluid. Do a search on hub oil on here and you should find the info you are looking for.
Old Jul 2, 2004 | 06:41 PM
BigBadScrambler's Avatar
As a substitute, you can use ATF type F, or even better, use Mobil 1 synthetic ATF. I have found the Mobil 1 to work the best, plus you have lots lefts over for nest time. Beltdrive covered the refilling procedure though.
