FMF Q for Honda 450R?
Old Jul 2, 2004 | 12:31 PM
atvblitzer's Avatar
Default FMF Q for Honda 450R?
Is this Pipe a good trail pipe. This artical says it make good power and it is quite which I ride in the forrest and the rangers like to give tickets. FMF Q test
Old Jul 2, 2004 | 03:41 PM
CrayFish's Avatar
You need to be carefull about these type of tests. Yes they put the FMF Q pipe on, but they also took the air box lid off and rejetted the bike. They even said it did not require the bike to be rejeted-just recomended. I wonder if they put the stock pipe back on minus the lid plus the jetting if the pipe would make any difference other than the noise? Just something to think about.
Old Jul 2, 2004 | 07:52 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If you ride mostly in the national forest, this would probably be a good choice. No doubt, it isn't getting the max that you could get from a (loud) performance pipe, but you are getting a big sound reduction. Both my 400's are way to loud, and are going to get a "quietcore" insert as soon as I have time for a rejet. I ride the EX in the San Bernardino Mountains, and the muffler it presently has got damaged in an accident, so I do think I will be replacing it with a Q sometime in the near future.
On the other hand, a hot bike like the 450 needs a hot pipe! On it, I am going to go with the FMF Factory-4 full system (I have the PowerBomb header on both my 400's, and it is great). I WILL run the quietcore insert however! In the August Dirtwheels, they tested slip-on pipes for the YFZ, and the Factory-4 slip-on came in at 95.1 dB, enough to pass the 96 dB rule here in Calif. Good enough for me.
Old Jul 3, 2004 | 05:30 PM
twentycharacters's Avatar
In the majority of cases, stock will most likely be quieter than the Q. I hava a Q on my 250R and it really didnt make it any quieter than the silencer that I took off (it was a non-stock silencer). It changed the tone of the bike, but didnt make the db go down. It looks good on the bike though.
Old Jul 5, 2004 | 04:08 PM
450r's Avatar
I wouldnt bother with the Q ,just get the power core 4 and quiet core insert.after you jet for the pipe you really dont need to rejet when you change the core, and its easy to change out when you go to an area that does not have db issues
NewGuy2481
Oct 6, 2015 05:54 AM
rgjackson
Sep 17, 2015 11:21 AM
stcspiderman
Sep 13, 2015 05:15 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
Jason Campbell
Sep 7, 2015 02:25 PM
