when to change valve springs....
Old Jul 5, 2004 | 11:04 PM
toydoctor's Avatar
Default when to change valve springs....
ok,...ive been looking at aftermarket cdi boxes,but ive been told that i should replace the valve springs first with stiffer ones...
what do you guys think?
my bike is an 04 baja x with stock cdi,..e-series slip on...k&n,..jet kit,..15t front,..20" tires...ect...
is it worth the trouble for the few extra rpm's?...or will the stock ones hold up to more rev???
Old Jul 6, 2004 | 12:57 PM
biggerisbetter's Avatar
The stock spring on the DS are better than most aftermarket springs for other quads. Aslong as you keep stock valves in your head, the stock springs will work fine.
bigger.
Old Jul 6, 2004 | 01:05 PM
DuneMe's Avatar
I've heard 1-year with aftermarket cams but, that sounds a bit conservative.
What are the big boys doing?
Old Jul 6, 2004 | 02:53 PM
SANDMAN430's Avatar
i went with new springs, but i'm also almost at the 1 year mark. they seem to be working fine at this point.
Old Jul 6, 2004 | 02:56 PM
SANDMAN430's Avatar
that was for the new engine mods. with just a cdi stock should be fine.
Old Jul 6, 2004 | 04:10 PM
OregonDunePatrol's Avatar
With stock cams - keep the stock springs. If you go with aftermarket cams and springs, change the springs at least once a season - especially if you use dual rate springs that are not shim under bucket. You could wait until the springs shatter with shim under bucket, the only thing that will happen is that you'll need a tow home. If you wait until the normal dual springs shatter (without shim under bucket) you'll have a large repair bill.
Old Jul 7, 2004 | 02:17 AM
toydoctor's Avatar
whats a safe rpm limit to be at with stock springs??...what are my " safe " options for cdi's?....i was told if i rev to high, that the valves will "eyebrow" the pistons...
donintennessee
Jan 8, 2021 12:40 PM
Divergent12
Dec 30, 2017 08:33 PM
Ronk407NY
Feb 13, 2016 11:05 AM
KSJOHN
Aug 30, 2015 08:15 AM
yambam13
Jul 4, 2015 01:49 PM
