i have to get my raptor needles to the third clip, how do i do this
Old Jul 7, 2004 | 01:00 PM
Rider1169's Avatar
Default i have to get my raptor needles to the third clip, how do i do this
im totally lost, i took off the black covers to the top of the carb, and see the big springs, from there what do i do? im really lost
Old Jul 7, 2004 | 01:40 PM
Hayseed's Avatar
Pull the springs out and set them aside. Pull the vacuum slide assemblies out. (The rubber diaphram, slide and needle are all together.) I use needlenose pliers to pull the needle retainer out of the center of the slide but you can set it upside down on a bench and push down on the needle to get it out. There will be a small spring inside so be careful not to drop anything. Be sure to keep your washers and spacer in order. You have to take the e clip off the needle and move it to the 3rd groove on both carbs. When you put the needle and retainer back in the slide you will feel the o-ring seat into its groove. Good Luck.
bmxatv10
Oct 14, 2022 06:23 PM
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
Sep 2, 2015 11:15 PM
