HRC kit and curtis sparks pipe
Old Jul 8, 2004 | 09:52 PM
ridinredODB's Avatar
Default HRC kit and curtis sparks pipe
im thinking about getting the HRC kit next week and a curtis sparks pipe and header. does the HRC give the 450 more power all around or is it more top end? also what do you think of the curtis sparks pipe? ive heard the HRC gives it around 9 hp. i was also wondering if anybody else had any trouble with the stock 450r being doggy on the bottom end, mine is bone stock and it has some bottom end lag, is this normal? ive heard the HRC kit and a pipe will fix the bottom end lag.
any help will be greatly appreciated.
Old Jul 11, 2004 | 09:50 PM
450r's Avatar
the kit helps with a 13 tooth sprocket. all curtis sparks's parts rock. if you're going to run his pipe ,save the money on the kit and get a stage I cam, jet kit and filter. plus, if you run the pipe with the kit ,you should run a better filter.
kit w/ curtis pipe ,filter=$750-850
stgI cam, pipe ,jets ,filter=$650-750
and i'll bet money on the second.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 20, 2004 | 04:04 PM
Jeepon02's Avatar
I have 450r with HRC kit and Curtis Sparks full....it rippppps...yes the stock 450r is a bit doggy in the low end but the HRC kit wakes it right up...you will need to run a 190 to 195 main jet though...dyno at rear tire 49hp
Ken
Old Jul 20, 2004 | 05:31 PM
JTY2K's Avatar
I'm seen a 450r with a HRC kit & Curtis Sparks pipe....a rocket!!!!
Old Jul 20, 2004 | 10:24 PM
450r's Avatar
Ken
where was the dyno done?
Old Jul 21, 2004 | 10:17 AM
Jeepon02's Avatar
Monroe Honda,
Monroe Wis.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
vinrum
11
Aug 26, 2015 06:44 AM
Proud Father
Aug 19, 2015 10:08 PM
JohnnySplat
Aug 6, 2015 12:07 PM
traumajunkie
Jul 23, 2015 02:10 AM
