irratic idle??
Old Jul 9, 2004 | 02:31 PM
tbsleeper's Avatar
Default irratic idle??
well i just changed the pilot to a 30 so wouldnt that mean it would be running richer? but when it is idling irractly doesnt that mean its not getting enough gas. wen u first start it its really smokey so im happy to know its rich but then again if u put ur brake on when u riding with it idling like this it pings again[img]i/expressions/face-icon-small-frown.gif[/img] when its in drive its revving high enough to engage the belt and it will roll slowly from a stop but roll fast when u let off the gas wit out hitting the brake. kinda like a car. could it be due to not fixing the throttle adjustment on teh throttle line? i know i tightened it before because it was idling to low? should i loosin that?
Old Jul 10, 2004 | 12:49 AM
hondabuster's Avatar
Have you adjusted the air screw. This is the fine tune for the pilot jet.
carb
its #11 in this view.
Old Jul 10, 2004 | 12:52 AM
tbsleeper's Avatar
ya and i had it all the way out then mostly all the way in then i was turning the idle way in then way out and it was the same so i think the throttle cable thing is too tight
Old Jul 10, 2004 | 01:09 AM
Sceiks's Avatar
You might check for a vaccum leak between the carb and the intake......a motorcycle of mine did something like that and that was what i found.
Old Jul 10, 2004 | 01:12 AM
tbsleeper's Avatar
hmmm maybe the rubber flange on the carb is overlapped or sumtin i will check that too!! thanks
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
