1987quadracer no 2nd gear please help
Old Jul 13, 2004 | 03:59 PM
superevil's Avatar
Default 1987quadracer no 2nd gear please help
i just bought a 1987 suzuki quadracer,it needed a clutch so i could realy ride it around. it pops out of second gear.it will shift into second gear,but as soon as you hit the gas it pops right out. when the quad is shut off,you can put it in second and push it,and it will stay in second gear and turn the motor over,but as soon as you hit the gas,it pops right out. please help,im supposed to go riding this weekend,and i have no friggin second gear
Old Jul 13, 2004 | 05:05 PM
donzilla's Avatar
well it could be several things . weak shift can spring , weak springs behind the cam , bad shift fork , bad second gear , bad slider some can be fixed without spliting the cases like the springs and dogs , but the others you will need to split the cases . the springs are fairly cheap to do and i would try them first . regaurdless if it is internal they should be replaced also .
Old Jul 13, 2004 | 08:08 PM
92Racer's Avatar
My bet is on the cam gear spring. Mine use to do that as well a few years ago. Ended uptaking the whole thing apart to check it out. The spring was tired. Afetr fixing hat no more problem.
Old Jul 14, 2004 | 02:06 AM
superevil's Avatar
wouldnt the shift can spring cause all the gears to slip? what things would cause ONLY second gear to slip? i mean it doesnt pull AT ALL in second,it slips right out,but when im stopped and the engine is off you can put it in second,and roll it forward,itl make the motor turn just a second and then slip out.its definitely going to second,but not for long.
Old Jul 15, 2004 | 03:55 AM
superevil's Avatar
the cam gear spring is located under the clutch cover and clutch correct?> wouldnt that cause all the gears to slip?
Old Jul 15, 2004 | 03:07 PM
92Racer's Avatar
Cam gear spring is inside the main case. You have to split the case to get to it. What happens to it is when it wares out it doesn't let the gear fully engage in the gear shift cam so it pops out. Pretty common thing actually. It's also a goos time to inspect the gears and shift forks and shafts..
Old Jul 15, 2004 | 03:48 PM
MJE's Avatar
MJE
sounds like a bad 2nd gear.
Old Jul 27, 2004 | 07:10 AM
88lt250rquadracer's Avatar
i have a complete set of gears for a 87 quadracer. i bought it for a spair for my 88 on e-bay. come to find out i had a spair set in the box of parts that came with my quad and 87 is different ( i think) get back to me if interested
Old Jul 28, 2004 | 04:56 PM
1987ltsuzuki230's Avatar
that happen to my 125
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
