valves out of tollerance
Old Jul 14, 2004 | 11:33 AM
Starky's Avatar
Default valves out of tollerance
What happens when your valves are out of tolerance. My Griz seems to be losing power and the only thing I can think of is the vavles need to be adjusted. I have about 700 miles on it and still have not had them checked (bashing can begin here). It's not sputtering or backfiring but there is a definate loss of power.
Old Jul 14, 2004 | 12:22 PM
Doctorturbo's Avatar
GOT BOOST!
You will loose power, exactly like you said. Usually the engine will cut up on the top. I would do a compression check and see what you get, and then check the valves. If you have to adjust them, do it and then do the compression check again.
Old Jul 14, 2004 | 03:01 PM
Starky's Avatar
Looks like I am going to be busy this weekend, thanks.
Old Jul 14, 2004 | 10:04 PM
Sparkey's Avatar
Should not take you too long.
Old Jul 23, 2004 | 03:56 AM
Heywood's Avatar
maybe i need to check the valves on my big bear. how do you adjust them?
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
