how can i get more ground clearance on a 400ex
In addition to those mentioned, go to a smaller front sprocket, smaller rear sprocket, switch to Honda 250r brake setup. Then, you can modify your rear skidplate. You will gain about 1/2" clearance if you do it right. If you go to 22" tires, move to a 13 tooth front sprocket instead of the stock 15 tooth.
/Jon
/Jon
/Jon
/Jon
Well.....unless you mean with the modded rear?
