how can i get more ground clearance on a 400ex
Old Jul 14, 2004 | 06:33 PM
IDLE's Avatar
Default how can i get more ground clearance on a 400ex
is there a lift kit or anything that would raise it....and if so tell me or give me a link thanks
Old Jul 14, 2004 | 07:19 PM
IDLE's Avatar
comon somebody
Old Jul 14, 2004 | 08:04 PM
cals400ex's Avatar
larger tires, longer shocks, or even try to stiffen up the stock shocks
Old Jul 14, 2004 | 08:28 PM
NotuRaptor2's Avatar
In addition to those mentioned, go to a smaller front sprocket, smaller rear sprocket, switch to Honda 250r brake setup. Then, you can modify your rear skidplate. You will gain about 1/2" clearance if you do it right. If you go to 22" tires, move to a 13 tooth front sprocket instead of the stock 15 tooth.
/Jon
Old Jul 14, 2004 | 08:55 PM
IDLE's Avatar
how would longer shocks give u more ground clearance......and how would they fit?
Old Jul 14, 2004 | 11:54 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
/Jon
22" tires and a 14 tooth front. Puts you pretty close to stock gearing.
Well.....unless you mean with the modded rear?
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
