banshee reed spacer ???
Old Jul 17, 2004 | 07:40 PM
fourjs's Avatar
Default banshee reed spacer ???
ok, here it goes, if you go engine-spacer-reed, does this help low or high end or is it engine-reed-spacer?? i heard that if you put it in one way it helps low end, put the other way it helps top, is this true??
Old Jul 17, 2004 | 07:58 PM
enFORCER's Avatar
Well first off reed spacers don't really help performance that much, they are mostly used when you install aftermarket carbs..... I had to put them on when I switch to 30mm keihin carbs so they clear the clutch release lever on the crankcase... [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 17, 2004 | 08:02 PM
fourjs's Avatar
i was hoping they help, in my mind anyway Ha, they were already on the quad when i purchased it, but someone told me the story of switching them, just curious if it was true or not....
Old Jul 17, 2004 | 08:58 PM
Imback's Avatar
Exactly what enforcer said...Unless you run bigger carbs dont waste any money on them,they fall into the boost bottle category as far as performance mods are concerned...
QuadRiders
Oct 22, 2015 04:13 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
