440EX Carb - Which is best?
Old Jul 18, 2004 | 05:01 PM
OregonDunePatrol's Avatar
Default 440EX Carb - Which is best?
Ive had a couple of aftermarket carbs for my 400EX starting with the Keihin 39mm when I had the stock bore. It was too much carb for the stock motor. When I moved up to the 440 kit, I got the Edelbrock 38MM "Doug Eichner" Carburetor. That carb makes the quad run nice, but it's simply not holding up well. After a multitude of lost screws, throttle wheel problems and finnally a broken pump shaft, I'm looking again.
Does anybody have a good 440 carb out there that will hold up to the riggors of dune riding?
Old Jul 18, 2004 | 06:30 PM
420EX's Avatar
Hands down the FCR 41mm carb is the very best carb out there. I couldn't be happier with mine.
Old Jul 18, 2004 | 06:57 PM
What kind of 440 mods do you have with that carb?
1) Piston Compression
2) Head Work
3) Valves
4) Cam
Thanks!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
