RAPTOR runs mint till I pull the clutch in!!
WHat do I do? I need to adjust the parking brake I think?? When I let the clutch out it rips and with it in it backfires and spits only when i get on the throttle!
both fine, it only cuts out when the clutch lever is pulled in, runs great otherwise revs good idles fine it even idles good with the clutch lever pulled in I cant figure it out??
no mods, and I have tried adjusting the idle. it started doing this a few days ago and I thought I had dirt in my carb or something then someone told me to check my parking brake and the lower wire that has the two speperate wires with a clip that plugs into the clutch lever was disconnected I clicked it back in and it reved fine again now its chokin only when the clutch lever is pulled in... Im boggled how can I eliminate the parking brake it never worked anyhow??
