RAPTOR runs mint till I pull the clutch in!!
Old Jul 21, 2004 | 08:44 PM
hellrider2001's Avatar
Default RAPTOR runs mint till I pull the clutch in!!
WHat do I do? I need to adjust the parking brake I think?? When I let the clutch out it rips and with it in it backfires and spits only when i get on the throttle!
Old Jul 21, 2004 | 09:39 PM
enFORCER's Avatar
Is your choke on? Will it rev up in neutral?
Old Jul 21, 2004 | 09:42 PM
choke is off and yes it revs up fine and even rips when I let the clutch out just while I have it pulled in it chokes
enFORCER's Avatar
You might want to check your air filter and your spark plugs......
Old Jul 21, 2004 | 09:49 PM
both fine, it only cuts out when the clutch lever is pulled in, runs great otherwise revs good idles fine it even idles good with the clutch lever pulled in I cant figure it out??
Old Jul 21, 2004 | 09:55 PM
enFORCER's Avatar
Have you done any mods to it? When did it start running bad? Have you tryed to ajust the idle?
Old Jul 21, 2004 | 10:03 PM
no mods, and I have tried adjusting the idle. it started doing this a few days ago and I thought I had dirt in my carb or something then someone told me to check my parking brake and the lower wire that has the two speperate wires with a clip that plugs into the clutch lever was disconnected I clicked it back in and it reved fine again now its chokin only when the clutch lever is pulled in... Im boggled how can I eliminate the parking brake it never worked anyhow??
Old Jul 21, 2004 | 10:06 PM
RaptorRider660R's Avatar
It is the Switch attached to the clutch I had the same prblem I had to adjust that switch on the clutch lever.
Nocando
Old Jul 21, 2004 | 10:07 PM
How do I adjust it?
enFORCER's Avatar
If it backfires when you let off the gas, it might be the result of a lean condition.... Look for a leak around the intake boot on the carbs.....
