How Do You Clean The Jet in a 1986 Suzuki lt230E Atv
Old Jul 24, 2004 | 03:19 PM
hixc's Avatar
Default How Do You Clean The Jet in a 1986 Suzuki lt230E Atv
How Do You Clean The Jet in a 1986 Suzuki lt230E Atv. because of problems with idleing
Old Jul 24, 2004 | 10:14 PM
crispy's Avatar
Idleing probelms, well if the simply Sh*t isn't the problem then your pilot jet is clogged, it doesn't matter how you clean it just use your head. run a small electrical wire through the hole then if you cant see daylight, try some other things..ie carb cleaner, water pressure, it's not that difficut man it's just a metal object with a small diamter hole in it all the way through.
godspeed
COFatboy
May 2, 2020 12:06 AM
WilliamBos
Jul 25, 2015 02:41 PM
JoAnnS
Jul 23, 2015 02:18 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Jul 15, 2015 02:07 AM
