How Do You Clean The Jet in a 1986 Suzuki lt230E Atv
Idleing probelms, well if the simply Sh*t isn't the problem then your pilot jet is clogged, it doesn't matter how you clean it just use your head. run a small electrical wire through the hole then if you cant see daylight, try some other things..ie carb cleaner, water pressure, it's not that difficut man it's just a metal object with a small diamter hole in it all the way through.
godspeed
godspeed
Jul 15, 2015 02:07 AM
