1984 200x losing power
Old Jul 26, 2004 | 05:15 PM
200XDiego's Avatar
Default 1984 200x losing power
My 84 200x seems to struggle when climbing uphill. I have replaced the plug and the problem seems to remain the same.
Does anyone have any suggestions where to start?
Any information/advice would be appreciated thanks.
Old Jul 26, 2004 | 07:44 PM
hondaguy13's Avatar
the hill could be too tall for the power that your 250 has
Old Jul 26, 2004 | 07:47 PM
PlatinumDogg's Avatar
Clean the carb out, check your plug gap, check your valve clearance...maybe time for a top end rebuild...piston and rings....how the compression looking...do a dry test...record, then do a wet test, drop a few tbl spoons full of motor oil into the spark plug hole...then test again..when doin this...best to have 2 people, one operating the throttle...(wide open) and holding the compression guage, other operating the rip cord or e-start....start from there w/ a compression test..and also check your plug..how does it look??
Sean
2quiker
Mar 22, 2022 08:36 PM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
