Welding
Old Jul 26, 2004 | 10:37 PM
02Bayou220's Avatar
Default Welding
I hit a rock and cracked the hole of my drain plug on my kawasaki and was wondering if it could be welded and then I would put in a helicoil. Thanks
Old Jul 28, 2004 | 01:55 AM
Kawibayou185's Avatar
Default Welding
Im glad im not the only one lol. I think its cast so you cant weld it, a heli coil might work mine just broke the top of the bolt so I was just able to buy a new one dont know about yours. Good luck
Old Jul 28, 2004 | 04:30 PM
hondabuster's Avatar
Default Welding
Its possible to weld cast aluminum, but whats gonna be a bitch, it makeing sure all of the oil is out of the crack. That will keep the weld job from being a solution. When welding aluminum, the area needs to be queeky clean. If youre pulling the motor, and are willing to get the area spotless, itll work to weld it.
Your best bet is JB weld. Clean the area, very good. Put the jb weld on, according to the directions, and it should be good to go. If the threads need to be fixed up, then either chase it with a tap, after the jb weld, and if thats not good enough, then helicoil.
Old Jul 30, 2004 | 04:28 PM
hondaguy2's Avatar
Default Welding
talk to a shop where they fix and repair props for boats. the can weld alot. where i work we had a guy weld cast iron, so it can be done.
Old Aug 3, 2004 | 01:26 AM
UltimateAussie's Avatar
Default Welding
jb weld
Valder
Nov 28, 2020 07:38 AM
bigred20653
Oct 2, 2015 10:05 AM
greg86hd
Sep 16, 2015 12:32 AM
DFWSRT8
Aug 20, 2015 09:24 AM
MNatv89
Aug 12, 2015 06:00 PM
