Gapless piston rings
Old Jul 27, 2004 | 06:49 PM
Hightower's Avatar
Default Gapless piston rings
Give it to me - pros and cons. If it was better, they'd all have it.
RWR new pistons have a gapless 2nd ring, it started on NOS pistons with the thicker crown, and now I'm told that they all come that way now.
But not everybody's does, so why?
Hey I'm learning, not stabbing, I know there must be reasons...
ANybody got a picture of a gapless ring?
Old Jul 27, 2004 | 07:01 PM
shmee's Avatar
my bros piston from rw had gapless rings. its a better way to go. mine didnot come with them. and i got mine after he did. i think you have to ask for them. it will have a better compression reading with gapless.
Old Jul 27, 2004 | 08:56 PM
Hightower's Avatar
I sent this to Elliot at RWR:
I assume the gapless ring reduces piston blow-by, am I to assume this will
decrease posotive crankcase pressure too and reduce the amount of oil that
gets coughed out of the crankcase breather?
I got this reply:
Gapless rings increase compression, especially at startup, decrease blowby, reduce oil consumption and a few other things they brag about that I can't remember just now. The way the DS is set up, oil vapor go through the balancer shaft and into the vent hose. If the balancer doesn't sling the oil away it goes through the vent hose.
Old Jul 28, 2004 | 12:40 AM
biggerisbetter's Avatar
I use the "total Seal" rings, and I like them very much. My motor used to cough up oil after a few long drags, but when I switch my rings to the Total seals it stopped that completely[img]i/expressions/face-icon-small-smile.gif[/img] I'm sure it helped with compression to, but it is not a noticable difference.
BIgger.
Old Jul 28, 2004 | 01:46 AM
WallStreet's Avatar
So why doesn't every manufacturer use them?
Old Jul 28, 2004 | 02:39 AM
DuneMe's Avatar
hmmm
I'ld like to see these on the 760.
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
