low rpm sputtering
Old Jul 29, 2004 | 02:39 PM
DuneRider650's Avatar
I ride a little here and there......
Default low rpm sputtering
2004 DS650 Baja X second gear when u pin it all it does it sputter u have to get it to about 3500rpm before u can pin it and have no sputtering........ on top end it runs awesome but on bottom end it sputters this is fixed if i take my air box lid off so is it my jets that i need to change?? Im 2450 feet above sea level
Old Jul 29, 2004 | 02:48 PM
shmee's Avatar
did it just happen or was always like that. and what have you messed with latly?
Old Jul 29, 2004 | 02:51 PM
no its been like this since i got it about 2 months ago thought maybe it was normal when i first got it but i think the jets needa be changed maybe the pilot jet?? and i havent touched anything
Old Jul 29, 2004 | 02:52 PM
and its in every gear it sputters when u just pin it really fast not just in second
Old Jul 29, 2004 | 03:30 PM
shmee's Avatar
its probably good to go threw the carb first. try that.
Old Jul 29, 2004 | 03:47 PM
crackerJack's Avatar
when I was having that problem it was rich. what main do ya have in and where is the needle? elevation?? It may work to just raise the clip on the needle a bit but most likely have to change a jet.
Old Jul 29, 2004 | 03:50 PM
2500 ft I see it now. With no mods I had to drop the needle down one to the second to the top clip. Use the stock main jet. Get a slip on and then move the needle to the second to the bottom with the stock main. Better yet get the end cap from hp research. I am at 3500 ft.
The elevation hear is 2450 and i dont no the jets but they are all stock
Old Jul 29, 2004 | 03:51 PM
alright im taking it in for a tune up at a local dealer ill have them do it for me
Old Jul 29, 2004 | 03:53 PM
Have ya got into the car at all. IT is really simple.
