low rpm sputtering
Old 07-29-2004, 04:07 PM
crackerJack's Avatar
Default low rpm sputtering
car= carb and ya only have to take the top of the carb off lift off the slide and change the clip. If ya are going to ride it many placed you are going to want to know how to do it. Your dealer should set it up for altitude for free. He will most likely say it is set up from 0-3000 ft from the factory but I guarantee ya it will run better with the clip raised one motch from factory. It is alot easier if ya put new bolts in the top of the carb because the factory ones strip easy. Have the dealer replace them with the local hardware store replacements. It made mine alot easier to get into.
Old 07-29-2004, 04:28 PM
DuneRider650's Avatar
I ride a little here and there......
yea thats why i dont wanna take it apart im worried about the bolt stripping because ive heard they strip easy and i dont no if that i do this by myself that it might void the warrenty?? somehow if something does go wrong i dont want the warrenty to say it was my fault because i wrecked the carb somehow by changing things
Old 07-29-2004, 04:32 PM
and im taking it in for a tune up anyhow so why not get them to do it??? and i have been into carbs before and i no it wont be that hard to do... right now when i go up higher elevation like in our sand dunes up here in the mountains i just take air box lid off runs perfect and pulls better that way anyhow
Old 07-29-2004, 04:53 PM
marrtoo's Avatar
To me it sounds like the choke is still in the first notch (not pushed all the way in). or maybe the air filter is dirty.
marrtoo
  #15
Old 07-29-2004, 06:52 PM
nope the choke is fine and the air filter is fine its been this way since i first got it... its the jets
  #16
Old 07-29-2004, 10:27 PM
Don't change the main jet just adjust the needle. The 165 mikuni works for all elevations with the stock bike.
ReconBayou
10-31-2022 05:37 PM
ltrmc02
08-22-2021 02:34 PM
Bernhard
09-25-2015 12:45 PM
Ricardo Covarrubias
09-17-2015 08:28 AM
Hw00d
09-10-2015 08:53 AM
Quick Reply: low rpm sputtering
