Mojave air intake
Old Aug 15, 2000 | 01:07 PM
Mojave87's Avatar
I have a 87 mojave and i plan on putting some mods on it i already have a few things but i really dont like the whole air intake system it is a really bad design. does anybody know where i can get an aftermarket air intake?
Thanks,
Ryan
Old Aug 16, 2000 | 03:58 PM
Sprocket's Avatar
I think you're stuck with the stock setup. It's such a strange design, it would be difficult to put anything else in it's place. You can try installing a K&N filter, and maybe some of those little air box vents to open it up.
Anyone else have any ideas?
Old Aug 17, 2000 | 04:50 PM
JD250R's Avatar
On my 1990 Mojave I took off the stock airbox and put a K&N pod filter on the carb. Works much better and is alot easier to take off and clean.
Old Aug 21, 2000 | 09:13 AM
Sprocket's Avatar
What is a "pod" filter?
Old Aug 23, 2000 | 09:11 PM
2punksdad's Avatar
my 2000 lakota has the same weenie setup, and the airbox was broken when I got it from the dealer........waiting to see if they are going to pay to replace it,,,,,,,,,if not I may go K&N also & drop the airbox. Is the majave still able to forge fairly deep water with the K&N pod?
Old Aug 23, 2000 | 11:34 PM
JD250R's Avatar
A pod filter is a filter that mounts right to the carb.
Old Aug 24, 2000 | 08:50 PM
JD250R's Avatar
Don't go with a pod filter if you ride in alot of water because the filter is out in the open and suck water into the engine. A UNI pod filter maybe a better choice, but I still wouldn't ride in to much water. If you like riding in mud and water, stay with the stock airbox and get a K&N flat filter and drill 3, 1 inch holes in the airbox lid.
Old Aug 24, 2000 | 11:01 PM
400exrydr's Avatar
in order to retain your posting privileges you must refrain from inflammatory or insulting posts.
ATVBBS
Old Aug 25, 2000 | 09:55 PM
2punksdad's Avatar
thank you atvconnection police..........my reply is no longer needed
Old Aug 27, 2000 | 12:03 AM
Mojave87's Avatar
how do i know what size pod filter to get?
