Tires for Honda TRX 90
Old Aug 2, 2004 | 09:38 PM
HondaFourtax90's Avatar
Default Tires for Honda TRX 90
Does anyone know any cheap tires that you could mount on stock rims of a Honda TRX 90? Thanks!!
P.S. The stock tires are 19x8-8.
Old Aug 3, 2004 | 02:45 PM
WB2JTE's Avatar
The wheels are like bead locks, what a PITA to change 'em. Even if you have a tire machine put a few pounds of air it them to break the bead.
Old Aug 4, 2004 | 04:05 AM
confusedbuyer's Avatar
I think Cheng shin knobbys are about the best bang for the buck you'll find. They are $20 each, from rockymountainatv.com + delivery, no taxes. the tire size is 20x8-8, and will easily fit your Honda. the knobby pattern is great for all purpose riding. It's what they use on dirtbikes (knobbies I mean).
I put them on our LT80 and LT160 (fronts), and I'm pretty sure my stock sizes were identical to yours. I have an old manual tire machine. I agree it's a real treat to try and break the bead, but I found a trick that worked for me. cuz the curve on the breaker bar is meant for bigger tires, only a small piece of it grabs these 8" tires, and then the tire slips and never seems to come off the bead. sooo.... I slipped a piece of 2" wide heavy flat iron under the breaker bar and up tight against the bead.I pushed down on the breaker bar, and it was just enough to break the stubborn bead. also, when breaking bead squirt lotsa soap or WD40, or penetrating fluid on the bead. when putting new tire on, clean the bead well with a wire brush, and use lotsa soapy water to help prevent tearing. also will help you get the tire to seat on (seating new tire was second hardest part, next to breaking the bead).
RickyMac
Mar 5, 2016 07:27 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
Jul 22, 2015 05:00 AM
rcappie4
Jul 18, 2015 07:51 AM
