chewing up front sprockets
Old Aug 4, 2004 | 03:55 PM
raptor660rle2003's Avatar
Default chewing up front sprockets
I keep losing a tooth on my front sproket, and bending all the rest. I have purchased after-market sprokets that are stronger and the same thing happens. I always keep the chain adjusted EXACTLY where it says...1.1 to 1.5 inches of play. Any advise?
Old Aug 4, 2004 | 04:00 PM
Flynbryan's Avatar
You may possibly have it misaligned.......? If your following the specs for chain slack I'm really not sure. Is it a new chain? You could have tight spots in the chain if its old/sacked out and it trying to jump teeth on you. If all the eqipment is new I really can't think of anything. Check and make sure your rear sprocket isn't bent.
Old Aug 4, 2004 | 04:09 PM
well i just got a new CZ racing chain
Old Aug 4, 2004 | 04:15 PM
RaptorOwner's Avatar
I would check the alignment marks on the rear swingarm and make sure they are adjusted equally.
Old Aug 4, 2004 | 05:02 PM
maddog56's Avatar
Is that the chain spec? Sounds awfully loose to me. I've been adjusting chains since I was old enough to hold a wrench and usually keep mine at about 3/4". You really shouldnt be able to see the chain sag much if at all.
Check to make sure you dont have the case saver or something interfering with the chain. Also check the clearance on the skidplate and that the rear sprocket hub is nice and tight and doesnt move around.
Old Aug 4, 2004 | 07:09 PM
ItalianStallion's Avatar
Yup....Thats what I think too....That would definatly chew a sprocket[img]i/expressions/face-icon-small-sad.gif[/img]
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
