Extreme problem please help!!
Old Aug 5, 2004 | 06:32 PM
RickyD650's Avatar
Default Extreme problem please help!!
Ok. I have a new problem when I start my DS it starts perfectly and also idels fine but then when I go to give it gas even if it is in neutral it just stalls I have know idea what could be wrong please help me! thanx
Old Aug 5, 2004 | 06:40 PM
blue250r's Avatar
Its probably not this , but mine does the same if its running on the choke its fine once the chokes off
Old Aug 5, 2004 | 06:42 PM
Billsner's Avatar
take a look at your neddle jet, once the plunger that holds it in came lose. causing similar symptoms.
Old Aug 5, 2004 | 07:32 PM
SANDMAN430's Avatar
make sure there isn't any holes in the top rubber diapharm on the carb
Old Aug 5, 2004 | 07:41 PM
biggerisbetter's Avatar
also, make sure your needle&float are not sticking. it almost sounds like your running out of gas. make sure the bowl is fill ing up.
bigger.
Old Aug 5, 2004 | 07:49 PM
DuneMe's Avatar
See your other thread!
You have enough fuel to start the bike but, the air not being allowed into the tank is also restricting your fuel flow.
Take off your gas cap and it will go!
The fix / your breather vent is pinched - Just like the posts say in your other thread.
Old Aug 5, 2004 | 09:36 PM
RickyD650's Avatar
Thanx guys for all ur help the problem was that i did not have enough gas and the I was running on regular and nor restricted but thanx anyway!![img]i/expressions/face-icon-small-smile.gif[/img]
hondarider1234
Jul 21, 2015 11:53 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
HondaR24
Jul 16, 2015 10:45 AM
Unzzy66
Jul 11, 2015 10:01 PM
