94 no spark
Old Aug 6, 2004 | 05:18 PM
DS650BajaRunner's Avatar
Default 94 no spark
Have problems once again with the 94 warrior. This time is that it produces no spark when i try to turn it over. I changed the CDI unti just incase nothing, I removed to stator to have it checked tomorrow. But i was just wondering if there might be other problems causing it to not produce spark any ideas or suggestions are appretiated.
Old Aug 6, 2004 | 07:03 PM
nighthawk68's Avatar
Default 94 no spark
coil
Old Aug 6, 2004 | 07:06 PM
Default 94 no spark
I was thinking the same thing since i try to measure the coild and it didnt read a thing. But i wasent sure.
Anyone else?
Old Aug 6, 2004 | 10:46 PM
Default 94 no spark
Anyone have a slight idea i need some help here people.
Old Aug 7, 2004 | 05:08 PM
Default 94 no spark
Bump???
Old Aug 8, 2004 | 01:56 AM
Default 94 no spark
check and see if you have voltage going into the coil. if not the problem is before the coil and if so then the problem is probably the coil. sometimes you just have low amount of power going into the coil and that could be it but i dont know what else to check.
Old Aug 8, 2004 | 02:02 AM
Default 94 no spark
I found the problem it was a loose blue wire in the pick up coil. After that it made spark and started right up thank for your help nighhawk really helpful.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
