how is the vitos big bore kit?
Old Aug 7, 2004 | 12:38 AM
prick's Avatar
Default how is the vitos big bore kit?
hey
How is the vitos big bore kit? does anybody have one?what is the best pipe(toomeyb1) to go with it?should you use the degree key also?many question?sorry
thanks
Old Aug 7, 2004 | 01:27 AM
daputz's Avatar
the vito's big bores (blaster), can be made into something special...........but you have to send it to someone too have it re-ported. The engine builder I go with has redone a good # of the se 240 kits........your best best is to buy a bigbore kit that is already ported to your power needs (see link in sig).
The toomey is great if you plan on running with stock porting, if you plan on modifing your engine in the future an lrd, cpi, or power pro's would be a much better choice.
Instead of paying $20+ for degree key, and $15+ for a flywheel puller. Just buy the flywheel puller and slot the stator plate, the results are the same, and you are less likely to shear the key.
ignition advance
Old Aug 7, 2004 | 12:19 PM
prick's Avatar
thanks guys,
i was looking at buyer a 2003 blaster that already had a vito kit, toomey pipe.v force reed, and k&n air filter.i was wondering if it was worth it?thanks you the info.
thanks
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
