warrior not starting
Old Aug 11, 2004 | 01:13 AM
2phast4u2catch's Avatar
Default warrior not starting
my warrior isnt starting i went riding thru mudd and water but not very deep probally only 6 inchs deep at most and then brought it home and shut it off then i started it and shut it off 2 times after that within 10 mins then while it was started in neutral when i went to get bak on it my foot hit the shifter and shifted it into first and it stald havent got it started yet wat do u think could b the problem when i hit the start butten a ticking sound comes from he back near the battery where the electric is do u think it might b wet or blew a fuse or what
Old Aug 11, 2004 | 10:14 AM
NLWarrior01's Avatar
sounds like your connects got muddy ... clean them off gently and try it again. Don't tap your starter either .. you can really bugger it up. A buddy of mine had starter trouble on his big bear (same engine really ..) and tapped it .. destroyed the rotor .. he was lucky and got one 2nd hand. If cleaning the connections around your starter relay don't work, then try bumping the starter position by pushing the quad while in gear (like jump starting) .. That could shift the pole off any bad spot that might be there and allow your starter to turn.
If that works then you need your starter rebuilt. Take it to an alternator/starter shop and they should fix it. That's the biggest thing I dislike on the Warrior is no secondary starting method.
Good luck!!
Old Aug 11, 2004 | 10:23 AM
well actually on my warrior i got a recoil back up and i tried that its just really hard to pull it out but i got it started up this morning i let it dry off al night
Old Aug 11, 2004 | 10:25 AM
Glad to hear you got it going again .. now that it's dried off get yourself some spray silicone electrical sealant and coat your wires really good. That should help prevent the problem from reoccuring ..
Old Aug 11, 2004 | 01:56 PM
99WarriorCustom's Avatar
I have encountered the problem with my Warrior too. Check the teminals on the battery. Depending on how old your battery is they may be corroded. Take a wire brush or grinder to clean them up to ensure a good connection is made. Also check that it is charged. Those are the only two reasons I have ever heard those noises..
Old Aug 11, 2004 | 02:35 PM
moldycheese's Avatar
try charging ur battery to. i had a warrior for a couple of years when i drove it in the winter i had that problem. when i boosted it with the car, it started right up
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
