oil?? kawasaki or synthetic?
Old Aug 17, 2004 | 07:34 PM
coonelder's Avatar
Default oil?? kawasaki or synthetic?
what is the best or does it matter? kawasaki oil or a good synthetic? or what about something like lucas?
360 prairie[img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 17, 2004 | 08:49 PM
WVatvRider's Avatar
Kawasaki oils/Honda Oils/Suzuki oils are repackaged Mobil or Kendall oils minus a few additives.
Lucas oils basically improve viscosity, and arent much but snake oils.
Synthetics are good for reducing temps and wear, or if you want to double your drain periods.
The best bang for the buck motor oils are Diesel 15W40s, heavy duty oils with no friction modifiers.
If you want to go with synthetics the best bang for the buck is Shell Rotella 5W50 in the blue jug at Wal-Mart.
Old Aug 17, 2004 | 10:02 PM
Chris142's Avatar
Kawasaki's oil is made by Motul. Says so right on the back of the bottle.
Old Aug 17, 2004 | 10:37 PM
scottd's Avatar
Since the P650, P700, and Brute don't have a wet clutch, is it then OK to not use a motorcycle-specific type of motor oil? Also, how long would you guys go on break-in before switching to a synthetic oil?
Old Aug 18, 2004 | 02:09 AM
WVatvRider's Avatar
"Kawasaki's oil is made by Motul. Says so right on the back of the bottle"
Good to know. I never would use Motul in motocross bikes or streetbikes due to the French ownership. Personally I still have a bad taste in my mouth of what the French did to us....but I am sure it is good oil for all intents and purposes.
250 miles or more would be a good number to shoot for to switch to synthetic. You want to make sure that the rings seat well and that the cylinder walls are good and smoothed out.
Redline Oils had a PDF about not using their oils during break-in.. good synthetics wont allow the rings to scuff the cylinder walls down to a fine smooth polish.
Old Aug 18, 2004 | 09:44 AM
CWG's Avatar
CWG
Good to know. I never would use Motul in motocross bikes or streetbikes due to the French ownership. Personally I still have a bad taste in my mouth of what the French did to us.....
roger that-
Old Aug 18, 2004 | 01:33 PM
steve55's Avatar
Just some more info at this link I found: http://www.allsyntheticsgroup.com/break-in.html
I broke in my rebuilt Mojave engine with synthetic-no problems whatsoever.
Old Aug 18, 2004 | 02:57 PM
CWG's Avatar
CWG
Jeez, got so fired up to bash ****** I forgot to add, after 100 hours synthetics should be good on most engines, I run it in both cars, the tractor, the lawnmower, the ATV.
The toyo went from 24 to 26mph, the van stayed the same, the tractor turns 200 rpm higher, so they do the job!
If we all ran synthetics we could start to kiss the you know whos good bye!
And alchie for the engines!! Grow more corn!! sorry....thread hi-jack
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
Alex G.
Sep 19, 2015 06:34 PM
wendal
Sep 15, 2015 01:50 PM
