Headlight conversion kits?
Old Aug 20, 2004 | 12:51 PM
silverbullet2005's Avatar
Default Headlight conversion kits?
does anyone know how to make one of these "headlight conversion kits", I found a kit on ebay which showed the picture of the "kit" which came with two scotch lock connectors and a jumper wire with two different color wires and some heatshrink tubing covering some sort of splice in the center. are these "kits" just two pieces of wire with a diode spliced in or what. if anyone knows could you please let the rest of us know how to make and install our own kits so we can quit making all those freekin ebayers rich.
Old Aug 20, 2004 | 12:58 PM
MrZeeedler's Avatar
What type of headlight coversion are we talking about? How to get both lights on at the same time? Im pretty sure you just take the wires from 1 and tap em on to the other one. Which might mean that only the switch would work in 1 mode.
Old Aug 20, 2004 | 01:04 PM
I am interested in the three headlight conversion to turn all three lights on in the high mode.
Old Aug 20, 2004 | 01:16 PM
BikKat's Avatar
See this link
SLG
Old Aug 20, 2004 | 02:48 PM
lovemud's Avatar
just take a toggle switch and splice into the yellow and green wires. it's about 99 cents for a switch, when you trip the switch and turn the lights on all three wil light or off it will work as originally designed.
Old Aug 20, 2004 | 03:14 PM
thanks, I am gonna try this either tonight or tomarrow. so let me get this strait. I just take the two diodes and twist them together parrallel or inline with each other. then solder them to a piece of yellow wire and green wire then splice that into the yellow and green wires on the quad with 3m scotch locks? and this worked on yours right? the wires can be found inside the guage pod under the plastic?
Old Aug 20, 2004 | 10:47 PM
well I've got good news and bad news. the good news is that I stopped by radio shack on the way home from work and they had the rectifier/diodes in stock
which were part number 276-1661. I borrowed the green and yellow wire from work and put them together tonight. the bad news is that I did not have time to install the kit on my 700 EFI tonight because it's to late at night to go over my father in laws house where I keep the quads. the diodes came in a pkg. of 4 so I made 4 headlight Kits. I am going to put one on both of my 700 EFI's. I used the pink heatshrink connectors to crimp the wire to the diodes I then heated the connectors to shrink the plastic and covered the diode and connectors with heatshrink wrap. I connected the green wire to the side of the diode with the silver stripe and the yellow wire to the black side of the diode. thank you all for the help and I will post another update tomarrow evening after I install the kits.
Old Aug 23, 2004 | 11:22 AM
BikKat's Avatar
I just took one diode and two 3M splicers and attached them to the two wires and called it done.
SLG
Old Aug 23, 2004 | 11:56 AM
NBsportsman's Avatar
If you just put the switch between High and low all three light come on. Its a little tricky to get but once it's there it will stay....
shimanok2
Jan 29, 2016 07:37 PM
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
PrairieDog126
Sep 16, 2015 01:33 PM
Alex G.
Sep 16, 2015 12:13 PM
