deadman anchor for winching
Old Aug 20, 2004 | 10:02 PM
wringer's Avatar
Default deadman anchor for winching
Has anyone ever tried an aluminum "danforth" type boat anchor as a deadman for winching? Was just down at the local marine supply store checking out some other stuff and they had quite a selection of take-apart aluminum boat anchors. Sort of looked like a 4 or 5 pounder would be just right for soft ground. Curious if it would be strong enough.
Old Aug 21, 2004 | 12:50 AM
BareTread's Avatar
i dont think a dead man is good for anything. after all he cant move or do anything. and you cant use him as an anchor because bodies float.
Old Aug 21, 2004 | 02:10 AM
Grimmsniper's Avatar
LOL !![img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 22, 2004 | 12:53 PM
Coyotechaser's Avatar
There is a product out on the market shaped like a "T" that screws down into the ground. Then you attach a winch or whatever to that.
I don't think an anchor would work well. The pulling of the atv and the suction of the mud might pull the anchor right out of the ground. You'd really need something that can go deep enough to hold the weight. But can also be removed afterward.
Old Aug 24, 2004 | 11:13 PM
Shortcut's Avatar
Fluke anchors do work, I know someone that carrys one in his box. They are somewhat tricky to get set.
Old Aug 25, 2004 | 12:34 AM
Are they hard to remove afterwards?
Old Aug 25, 2004 | 04:52 PM
MBullism's Avatar
Boat anchors will work, but like everything else, not always..not everytime. I've used a LARGE one for pulling my CJ-5 out of some predicaments. It was standard equipment on the beach where there wasn't a tree for miles....
Old Aug 25, 2004 | 07:14 PM
Shortcut's Avatar
Some of these type anchors have a ring or shackle that when pulled the opposite direction slides down the shank and releases the fluke.
Old Aug 26, 2004 | 12:07 PM
1Toby1's Avatar
This is what you need...
pull pal
Old Aug 30, 2004 | 11:47 PM
Outrage's Avatar
This thing looks like it will work but isn't there something a little smaller than 32"?
