deadman anchor for winching
Has anyone ever tried an aluminum "danforth" type boat anchor as a deadman for winching? Was just down at the local marine supply store checking out some other stuff and they had quite a selection of take-apart aluminum boat anchors. Sort of looked like a 4 or 5 pounder would be just right for soft ground. Curious if it would be strong enough.
There is a product out on the market shaped like a "T" that screws down into the ground. Then you attach a winch or whatever to that.
I don't think an anchor would work well. The pulling of the atv and the suction of the mud might pull the anchor right out of the ground. You'd really need something that can go deep enough to hold the weight. But can also be removed afterward.
Boat anchors will work, but like everything else, not always..not everytime. I've used a LARGE one for pulling my CJ-5 out of some predicaments. It was standard equipment on the beach where there wasn't a tree for miles....
